Old Can Ride
Today's o ring chains are so good, I bet on 8000 if not more before linkage problems.
Good luck !!.
I did this same test with my Vstrom ( I was being stupid and lazy ) and after 8,000 miles my chain started kinking and it was shot.After that I used a LubeMan and got about 13,000 miles but it was to messy so I went back to semi regular manual lubing and got around 11,00-12,000 miles out of the next one.
I have a friend with a DL650 that cleans and lubes his chain after every ride ( even if it's a 50 mile ride ).Not only does his chain look like it was just put on but at 60,000 miles he's on his second chain,the stock one lasted 40,000 miles!!.
WOW! That's impressive.
It is, indeed. But I would be curious to know how much he spent on the products it took to get that much extra life out of it and if it wouldn't have been cheaper to have just replaced chains a couple of times instead.
On my 2009 G650gs I just traded in for the Nc700, I did normal chain maintenance every 400-500 miles: cleaned the chain with kerosine (sp?) and small wire brush. Wiped cleaned, and then either used Lithium grease or Honda chain lube. Once every 6 months I would coat the chain with high temp boat bearing grease. I got 32,000 miles on the chain and sprockets and the only reason I changed the set was my rear sprocket had points on the teeth. The front sprocket still looked like new (changed it anyways) and I changed the chain even though there was no stretch and no kinks in the change. If you have to change one part of the component, might as well change all 3 while you are doing it.
I'm not a WD40 zealot - I'd gladly use another product that works well and minimizes chain cleaning effort. Most chain cleaners/degreasers I've come accross suggest rinsing the chain with water after application and before lubing. That's at least a 3 step process, if no chain scrubing is done before or chain wiping/drying after the water rinse. Furthermore, putting water on a metal chain is counter-intuitive to me - shouldn't that be followed by a Water Displacement application (yet another step)? Using WD40 simply saves me the degrease, rinse and dry steps.
Since I live on a dirt road, my chain starts collecting dust as soon as I leave the garage. I'm sure the accumulated grit accelerates chain/sprocket wear, so I should clean my chain after every ride to maximize chain/sprocket life. That's too much effort for me and would totally ruin the whole motorcycle commuting experience. However, I would likely clean/lube my chain more often if I could get it down to a single step process - spray something on the chain that washes away the accumulated dust, provides sufficient external chain lubrication (if necessary, as Lee and others have questioned) and minimizes dust accumulation.
Other than the lubrication, WD40 seems to do this quite well. Another light oil based product may also clean the dust off (e.g. Dupont chain saver), but would then attract more dust as soon as the tire rolls down the dirt road. The Maxima chain wax I use isn't suppose to attract dirt as well as oil, but it doesn't clean the chain very well by itself. So for now, I have a 3 step process: 1) spray the chain with WD40, 2) wipe off the chain, 3) spray the chain with chain wax. The second step is the messiest and takes the longest amount of time, but I believe is necessary for the wax to stick to the chain.
I'm open to try other chain cleaning/lubing products, that is if I can find them and they're not more expensive that what I using now.
This is what I did this morning, exactly !!! I normally just wax the chain (no cleaning) BUT today I noticed my chain was a little dirty (rode some offroad while on my trip) . Sooooo I looked around and grabbed the WD-40 soaked the chain down and used my new chain brush, then used a towel to dry all the grime off the chain/rear sprocket. Then with the bike on the centre stand running in 1st gear (to warm the chain up abit) , I used chain wax to re-lube the chain. Looks good !!!
<snipped>Then with the bike on the centre stand running in 1st gear (to warm the chain up abit) , I used chain wax to re-lube the chain
I'm not going to post the gory, graphic photos of people that have lost their fingers or finger tips lubing a chain with the engine running and the bike in gear. You can easily find those pictures on the Web if you want to see a reason not to do it that way. Just sayin'. Be careful.
