jmzd4
Jmdz4,
That music makes me think a supermodel is about to appear by the side of the road.
Yeah, that would have been nice. I could have given her a ride
Jmdz4,
Well there's my excuse to pay someone else to change the tires and for me to put off buying the tools to do it myself lol. I'm a cheap skate and was just thinking of buying the tools to change the tires myself and I was planning on trying those balance beads? The tools are the price of a couple tire changes so not a bad deal. Never used the balance beads before usually use the liquid ride on. Any opinions on that?Replaced both tires on my sons 2012 X model. (Sunday) No pics but dang if the bead breaking and removal of the five year old tires wasn't a total BIICH!!! We ended up using a 6' lever against a piece of pipe (2X4 kept slipping) that would dig into the tire. The lever lifted the bench with me leaning on it so we put the fulcrum under a truck spring. What torture.
I know the bead breaking tools/stands with the 3' arm would not have worked. And the U tube videos showing all the easy roadside removals made us want to cry. I mean one of these dudes broke a bead with the heel of a boot (and some good positioning) No way here!! _+_@#)(%&@#@#%)(&*@%!! My son is 300lbs and both of us leaning down on a bar did nothing. Lube and all.
In the 70s I did a tire change on a side walk in a drizzle with a tool called a Breezer. That was good but our rims were steel, like our balls. Now the rims are aluminium and soft. I even cut through the fancy protector and gouged the rim with one tire tool.
Did I mention the removal was a total, unadulterated, horrid BIICH?
Whew glad that is off my chest.
P.S. Just how important is it to get a perfect balance on a bike that can barely get to 85mph before running out of road.
You can get a led headlight to match your auxiliary lights $20-something or soI installed the 20 inch Madstad windshield but still felt some wind buffering. I had ordered the eBay windshield attachment thing a while ago and decided to add it and I sort of dig it. I'm actually pretty impressed how well that attachment thing is made.
Here's the bike with the cheap LED lights. Not overwhelmingly bright but it does the job.
Was it cold? Might've been a bit easier if you warmed up the tire first (either let it sit in the sun, in front of a heater, or even just ride it for a while--issue with that being you have to remove the wheel while the bike is hot, then the tire before it cools).
Sorry to hear you had so much trouble, but I don't think it should normally be that bad. I use a Harbor Freight bead breaker and never had any trouble with motorcycle or trailer tire beads. Maybe it's because the bead breaker tool applies the force right next to the rim.
A few weeks ago I changed the OEM tire on my wife's Honda Reflex scooter due to it's age. It was on the rim for 14 years and it came loose with no problem at all using the HF bead breaker.
I've used Dynabeads on my old Goldwing but switched to Ride-On. With Dyabeads, if I had to plug a flat tire, I'm betting they would stick to the plug and screw the balance up . Not a problem with Ride-On.
Why would you need a plug if you have the stuff in the tire?
