D
Deleted member 4929
Rode to Cycle Gear for supplies; then changed the fork oil.
I hope you at least have some foam mats or something to make it easier on the knees. I picked up some of the brightly colored Lego tile type at a garage sale, saves the shoulder blades when crawling under the car and the knees when working on the bikeHaven't ridden since the surgery Nov. 29. Went out to the garage and worked on the SL350. Changed the steering bearings. Need to do a valve adjustment on the NC. Wish I had a lift. This old man is having a hard time getting up and down on the cold concrete floor.
I don't understand what do you mean about adjusting the clutch vs the brake? The clutch is more adjustable then the brakesFirst oil change, chain cleaning and adjustment of cables. Really wishing the clutch was adjustable like the brake
He means the lever. The 2014 has an adjustable reach brake lever, but not an adjustable reach clutch lever.
Aftermarket levers would be the solution to having both sides adjustable. Why Honda did one and not the other, I don't know.
Yeah if they made one adjustable they should have made both. My NC700X is a 2012 so I got some $20 Amazon adjustable levers and I'm happy with themThank you for clarifying. I agree honda should have made both adjustable.
Left side (same as clutch lever) in between the frunk and body work. Plenty of room out of sight and the elements, fairly easy to get to, well easier then changing the air filter. I was able to fit two outlets and switches with plenty of room to spareInspected bike, considering locations to install fuse block/relay and controls for heated grips and future accessories, and what combination of parts. There are many options, just need to decide. lol
Nice, post pics when you get it togetherToday I ordered the proper '1146' GIVI kit items from motorstorm.it to bolt the trekker outback side cases to the NC750X. (same plastics NC700X)
This will replace my home-made bent steel mounts. I also ordered the Trekker top case in black to go with the silver side cases.
It should look pretty sweet on the 2016.
