Wheels
.... one month overdue .... Oh well
Saaame. Looks like the DCT models are slowly starting to trickle in across the US, but haven’t seen any reports of manual NCs arriving yet (aka my bike)..... one month overdue .... Oh well
I was told that also in Europe and in general there is a difficulty into transporting all the bikes to the destinations due to limited transportation capabilities (aka ships). Enough motors in Honda Japan, they issue is bringing them to the other side.Saaame. Looks like the DCT models are slowly starting to trickle in across the US, but haven’t seen any reports of manual NCs arriving yet (aka my bike).
If someone is near New Jersey, though, Hanover Powersports had a ‘21 DCT model in stock as of this afternoon.
I have no problems with the 2012 sidestand. I can even mount the bike while it’s on the sidestand and it is adequately sturdy. If you are concerned, I would suggest you check the mounting hardware on yours to be sure it’s tight.Probably just me but thought I'd ask...has anyone else thought the kick stand on the 750 is kinda wimpy? Some of this may (is) spring compression in the rear but have noticed when I park with the stand down hill and dismount it seems like the added weight of the bike leaning makes the side stand slide and almost feels like it is "bending". Without crawling under the bike which is a chore these days, just looking it seems just fine an no bending or anything unusual.
Anyone else experience anything like this???
Thanks Greg...will do.I have no problems with the 2012 sidestand. I can even mount the bike while it’s on the sidestand and it is adequately sturdy. If you are concerned, I would suggest you check the mounting hardware on yours to be sure it’s tight.
I did add a big foot to the stand to keep it from sinking in the dirt.
Maybe this apparent stand weakness is an issue with 2021 models? We’ll see if anyone else has a similar observation.
I think it leans over more than it should so I park on a board in the garage, but I mount mine by stepping on the left peg cause I have stubby legs and it's a real stretch to get my leg over the seat standing on the ground.Probably just me but thought I'd ask...has anyone else thought the kick stand on the 750 is kinda wimpy? Some of this may (is) spring compression in the rear but have noticed when I park with the stand down hill and dismount it seems like the added weight of the bike leaning makes the side stand slide and almost feels like it is "bending". Without crawling under the bike which is a chore these days, just looking it seems just fine an no bending or anything unusual.
Same problem Good Buddy!!! I do that on bigger bikes...step on the left peg and swing over. I've done it from the right side too and it seems easier since the left foot just naturally slides to the ground once you get it over the seat. I'm kinda concerned about stepping on the left peg on the NC since it settles down when I step on it and that what makes me thing the side stand is "flexing" or some thing. I have #1 son check it when he gets home.I think it leans over more than it should so I park on a board in the garage, but I mount mine by stepping on the left peg cause I have stubby legs and it's a real stretch to get my leg over the seat standing on the ground.
I've mounted my bike from the right countless times, stepping on the peg and swinging my left leg over. I've even pulled my NC onto the kickstand to spin it while trying to manouver out of or into a tiny garage.Same problem Good Buddy!!! I do that on bigger bikes...step on the left peg and swing over. I've done it from the right side too and it seems easier since the left foot just naturally slides to the ground once you get it over the seat. I'm kinda concerned about stepping on the left peg on the NC since it settles down when I step on it and that what makes me thing the side stand is "flexing" or some thing. I have #1 son check it when he gets home.
In addition to shimming the pivot point, adding a foot stand pad would not only offer more surface area but also lengthen the stand a little, lessening the lean.There have been one or two posters I can remember that posted about weak or bent side stands. Not many really given the time frame.
My 2013 has a bit of play in it that allows a little too much lean-over for me. I inquired about replacing it and found that Honda has them on back order at the moment with no open purchase order date for replenishment. Hmmn. I'll try shimming it.
Thanks Ferret!!Gorgeous pic lowrider. You live in a beautiful place.
I usually weld a 3" steel washer about 3/16" thick on the bottom and they don't sink much and offer a larger area. That might help with the length too.In addition to shimming the pivot point, adding a foot stand pad would not only offer more surface area but also lengthen the stand a little, lessening the lean.
Sounds like what I'm looking for...I've mounted my bike from the right countless times, stepping on the peg and swinging my left leg over. I've even pulled my NC onto the kickstand to spin it while trying to manouver out of or into a tiny garage.
Seems solid so far
