I average 67.5 mpg going 75 to 80 mph on I-40 to work. 44 miles one way. Bought my nc700x second weekend in August now have 7,000 miles on it. The money I save in gas makes the mounthy payments.
That is about what I get on mine.
I am getting an average of 58 miles per gallon over the last 3 fills. Also notice a clattering sound while accelerating. Is this normal? I am used to the smooth 4 cylinder engine on a Yamaha so maybe my perceptions are skewed. Is there something I should check because the mpg is not as great as some have claimed.
yep I will go with those figures. I am sure the miracle figures are only seen when you ride this bike slow.
Mike
One last thing. I have to confess to using 87 octane gas. Should I be using the mid-grade or even the high test stuff? Does it make much difference in performance? I may run a tank full of the good stuff through and check the results.
There's no reason not to use 87 octane (R+M/2) fuel, unless you just want to feed the oil company's bottom line. The "good stuff" won't make your NC run any better, unless you let your brain trick you into thinking that it does.
Uh, oh. The oil debate could become the fuel debate.
Greg
