Nortwestrider
Did you need the fender mod for the new 120/17 ,705 front tire ??.
Live life,be yourself !!!!.
That's not available yet, said July in post and I wanted to get both on now. Mine is the 130/80-17 and unfortunately I was unable to get it to seat on the rim today. I have a compressor that goes to 120lbs but I couldn't get the bead to expand enough to catch the sides of the rim. Any suggestions would be more than welcome.
Did you have the valve core in or out ??.
If you take out the core you get a bigger rush of air and that will sometimes seat the bead.
Also before I mount a tire I put a few 5-6" pieces of 2x4 between the beads and leave them in out in the sun or in the house for a couple of days to spread the bead apart.
Tie a rope around the center of the tread, tighten it and force the sidewalls out a bit more as you're airing up.[/QUOTE
The 705 is really stiff and doesn't really flex much. I just tried that and it doesn't want to come down enough to contact all the way around. Maybe this is an older tire and that accounts for the stiffness. I am probably headed for a tube.
Wish I had thought of that. Gap between the bead and rim is not going to be bridged unless I take it off and do what you suggest. Or go tube....Live life,be yourself !!!!.
Before you do a tube,take the tire off and put something between the beads all the way around and leave it in a warm place for several days.This will spread the beads and after several days in a warm place the beads will stay out and you should have no problems seating them.
I am a lazy bastard, so I have pulled one side up and used the rim to hold up the 2x4 blocks. I plan to leave it in the car tomorrow and hope that will do the stretch. With my luck it'll be one of the 3 cloudy days of the year here. Then I have to pre-stretch the rear tire, if it gets in tomorrow like it's supposed to. This is my primary transportation so I have to get this done ASAP.
Hey that's s great compromise,that should work.
I use a ratchet strap around the center of the tire. Has worked multiple times to get the bead close enough to the rim to seat.
Linking these posts together because the info can be helpful if your looking at 705.
Post # 69 in this link shows Shinko 705 now available in NC sizes.
http://nc700-forum.com/forum/tire-tech-talk/4984-tires-fit-nc700-7.html
The 705 120/70R-17 front I just installed is marked TUBELESS.
It appears the Bike Bandit site is offering more choices of the 705 than other retailers.
Some retailers do show the front tire for the NC.
anybody receive a 120/70-17 front yet
