Kyonic
Not at all good info
Mine's a clunker too... any time you put it in first, clunk.
Hi all! I had same problem but going worse. Began with loud clunk in first gear. Went on switching to second became hard. Now It is sextremely hard to switch upwards and i think by swithing it stucks. Doesnt go at once bit the mowement of the switch breaks in two. I hope it is only oil. However I have now 3800 kms in the NC and last oil change was at 1000. Has anybody got similar problem?
What kind of oil is in it?
What type of oil shall I tell them to put in? Or NOT to put in?
The owners manual say 5W30 rated SG and energy saving is not allowed.
I would tend to think a dealer would know the correct oil to use though ...
Has the shift lever, shaft and cable been lubed?
Welcome Vandis
You may want to check out this thread:
http://nc700-forum.com/forum/nc700-technical/3023-unable-shift-first-neutral-2nd.html
cburn mentions difficulty shifting from first to second gear, the actual problem, and a resolution involving a relatively minor repair required.
I'm not saying that's what your difficulty is, but if so, at least you know you are not alone, and it is something that can be solved without too much grief.
Read through the whole thread, but I think posts 34 and 38 on page 4 specifically list the actual part that was faulty.
Good luck with your efforts, and please let us know how it goes!
