BassBob
BassBob asking for info on front cowl replacement. What I'd like is what order do I start with. I'm guessing the pin is a locater for proper alignment. Yes?
It's the pin on the cowl which has a screw/grommet. The screw in in an almost impossible location to engage. I presume I install the screw/grommet and push really hard?
2nd question involves the upper clips on the cowl. There are two of them. One big one, and one little one. The little one is slightly bent. So, If I need to, can I just remove it?
I think this is why nothing seats properly.
I might be able to pry it a little bit to get it to seat. But like the locating pin/grommet, I suspect that's almost impossible too.
For what it's worth, I've checked manuals, and each one has a different thing that needs removal. (Like the windshield!).
Thanks in advance!
BassBob
Thanks in advance!
BassBob
