2016: What did you do to/with your NC700 today?
Status
Not open for further replies.
Installed the fender extender on my bike!
Sent from my Nexus 6 using Tapatalk
Rode through Gig Harbor, back roads to Olalla, out to Belfair, then to Allyn. Checked out the City Park and had a light lunch. Found my peace, then a ride along the water front and back home.
The new Shad comfort seat made the ride much more tolerable.
I changed my oil, not very exciting but here are some pictures!
Can someone tell me what MGS & D stand for?
MGS is used a lot in the designation of Honda part numbers.
D probably means this is a dipstick for DCT, since DCT takes more oil than MT.
Did you replace the DCT filter O-ring too - PN: 91302-PA9-003 ?
I'm collecting the stuff for my first oil change...
First oil change today, a little late at 1,240 miles. Oil filter was a little tight, and I didn't have a small enough oil filter wrench or a large enough channel-lock wrench...so I just punched a screw driver through the filter. The new K&N filter has the 17mm bolt head on it...much easier to install. I can't believe I don't have to do it again for 8,000 miles...but at the rate I'm putting on miles that will be in the late fall. I put 1239.5 miles on it in 6 weeks ;), and I have some long trips planned this summer & fall.
Oh, and I've decided to name her Black Betty.
Thanks for info on MGS D.
I bought the o-ring but the old one looked so good I couldn't bring myself to change it (it's hard being a cheap basterd) same for the crush washer on the drain plug! One thing to consider, the DCT oil filter cover has two 8 mm bolts. There is no mention in the owners manual about recommended torque, I was working with a 3/8" drive ratchet but switched to a little 1/4" ratchet to tighten up these 8 mm bolts, do not over tighten.
My first time changing oil in my 2014 DCT (went to the dealer prior). Things were going great until I tried to place the DCT oil filter cover back on. It cracked when I screwed it back on (was not even tight).
In ended up super gluing the parts together, then assembled everything back and filled it up with oil. Any one face a similar issue? or advice on if I should ride around (so far no oily puddles, but it's only been an hour or so).
They need to have a simpler, all metal solid, design.
Good idea I use a 1/4 ratchet, I try using it only for everything I can, I'm always worried about something breaking out stopping out
Bam-ba-Lam! Good times!
[video=youtube_share;R044sleOW6I]https://youtu.be/R044sleOW6I[/video]
Oddly enough, the Service Manual does not list torque values for bolts on the DCT oil filter cover in the 'Maintenance' section.
It does however list:
The oil sump drain bolt torque spec is 30Nm / 22lb-ft
The filter torque spec is 26Nm / 19lb-ft
Now, the Service Manual is a tricky thing, because it has a 'Standard Torque Values' section at the beginning that you're supposed to use when they don't list one elsewhere.
That bolt on the DCT filter cover, for the 2016 is:
BOLT, FLANGE (6X16) (NSHF)
90006-GHB-630
For an 6mm flange NSHF bolt, 'Standard Torque Value' chart says 12Nm / 9lb-ft
I always go by feel, with published numbers as a guide. If something feels like it's gonna snap, stop.
Best practice for this is to torque a bunch various size and hardness bolts into some scrap wood / metal with a breaker bar and snap them on purpose just to see what it feels like.
The more you know!...
Went to ride into work today, and the front end felt like I was riding through mud. Looked down, and the front tire was quite low. Went home, parked her and went to work the normal way...
Ordered a new tire Michelin Pilot Road 4, 120/70ZR17 and will get it put on tomorrow/Wednesday at Cyclegear. $120 + installation.
Tonight, I will be taking the front wheel off for the first time. Is there anything I need to pay attention to in regards to that? What about putting it back on Wednesday night? Please respond in Private Message rather than this thread.
2012 nc700s
Hey all, I hope everyone is excited about spring.....I have been lurking looking at your rides and mods and wanted to share a pic of my ride. I just finished wiring and adding my new lights. I also changed the wheel color. Looking to be different.....you know. Anyways, hope to see some of you riders on the road.IMG_20160502_141332 (3).jpgIMG_20160502_141342 (3).jpg
ooooh, beauty! I love the wheels and those monster lights :D
I'm a fan of the olden days of rally car looks, and the last of the big twin headlight motorcycles, just before the technology in lighting took off with projector beams/hid/led etc. :cool:
37412-Audi-old_car-car-sports_car-sports-snow-lights-audi_quattro-Rally-rally_cars-736x459.jpg
Status
