JDE
- Joined
- Aug 18, 2012
- Messages
- 1,463
- Reaction score
- 3
- Points
- 0
- Location
- Central Valley, California
I was thinking the same thing! I think he's bluffing. No pictures. It didn't happen.Pictures?
D'oh!
---> MICROSTART • Antigravity Batteries <---
The peace of mind having a micro jumpstarter tucked away in the bike is pretty awesome, if you can find one that fits your budget, I highly recommend them!
I think the last time I left my key in the ignition (not turned on though, thankfully) was in 1980 or so. In downtown Vancouver for the whole day, right out on the street. I came back to find someone had taken the key out at some point during the day, and put it in the gas tank cap lock, as a gentle chiding reminder to be more careful lol
Yesterday I purchased a used tinted MRA VarioTouring Screen. I got it installed this morning. Very excited to see if I can get rid of the loud irritating helmet noise that I get with the stock windshield in the low or high setting. Even with ear plugs it bothers me at highway speeds.
Didn't ride my NC yesterday, but what a GREAT 100 mile trail ride I had with a group yesterday on my CRF250L.
I'm still considering getting two of them. One for the front and one for the rear. I currently have two cameras I use but, they are pretty obvious and I have to remove them to charge after each ride. After getting rear ended I really want something more hidden/permanent and convenient. Amazon reviews for it aren't that great though, think that's the only thing holding me back.Installed an Innovv C3 today.
Mounted it under the beak. I measured everything and it should be fine, but you never know!!
230 miles in NC mountains on mundane roads with names like Devils Whip, Diamondback, The Snake, Crooked Music Road. Missed all the rain. Tough job but someone has to do it. Can't even get a day off tomorrow. [emoji6]
Cool. Thanks for the write up. I think I will pull the trigger on getting a couple soon. Now I need to get power to the frunk.I bought mine from the actual importer himself, directly, due to a GroupBuy on BayAreaRidersForum.com. Because of that, I felt comfortable with if I had any issues being able to get them fixed.
The reviews, even on the group buy, are hit and miss. It appears that some people suffer reliability issues with it, some don't. I tend to think people are using cheap SDCard's and that's the cause of the issue, *or*, wiring it to a non-fused battery directly, causing voltage drops and increases which causes the central board to shut down to protect itself.
In my case I plug it directly into the auxiliary plug in our FRUNK and that resolves any voltage issues that some people have had. So far, and it's only been a day, I've had no "reliability" issues. I've managed to reconfigure the configuration file (via textEdit) and add a timestamp, as well as my own wording on the bottom, and changed it to 10 minute video files instead of the default 3.
Quality is outstanding.. and so far it does work as designed. Turn key on, it records. Turn key off, it stops. Working on editing the .mov to post it, so you can see for yourself.
Here's a video of it being ridden by The Stig... yes it's a little canted, which I fixed by rotating the mount. The quality and sound is better than YouTube makes shows it, even at 1080p, but you'll get the idea. And it turned on and off automatically.
[video=youtube;XUuYS8svECk]https://www.youtube.com/watch?v=XUuYS8svECk[/video]
Installation info:
I mounted the lens to the underside of the "beak," with the standard 3M adhesive tape that came with the mount. I ran the wire under the plastics on the bottom side of the beak, up the dash support frame, to the main wiring harness on the left side of handle bars and then under the top triple clamp. Then I slid it through the bottom opening on the "front" of the "frunk," reached in behind the battery and pulled the wire through. Bolted the cover back on the battery.
This left me with the wire from the lens inside the frunk. Then I just plugged it into the "control unit," plugged the USB auxiliary power cord into my frunk-OEM honda accessory plug and tied it all into that little pocket on the front of the battery cover with the factory OEM honda rubber band thingy mabob.
Once I determine that it's reliable, I will mount it inside a plastic box of some sort to protect the lines and connections from other stuff in my frunk that may be roaming around.
I run quite a bit of sag in the front, more than most, and even with this much sag up front I was unable to even get the fender to come into view under heavy braking or when jumping off of curbs and stuff. I don't anticipate the lens ever touching the top of the fender.
