GT928
I have used a hammock as well in the past. I have a small nylon webbing hammock that folds up to the size of a softball or smaller. I put a small 3/4 self inflating backpacking pad in the hammock which helps it hold its shape and allows a little more freedom of movement. Having tried sleeping in different hammocks several ways, I can heartily recommend the addition of a pad in it. It has the added value of insulation. I would tie another line between the two trees above the hammock and drape a piece of visqueen or plastic tarp across to keep the rain off. I would use a rubber ball in each corner of the tarp and pass it and tarp through the big end of a wire loop shaped like the profile of a lightbulb and slide them to the small end and tie them off to 4 stakes. This works well when you have trees available and conveniently spaced as is the norm when backpacking.
When camping at motorcycle rallies, one cannot count on appropriate trees being there so I use a 2 man tent so that I have room to store panniers as well as sleep. I use a full length self inflating pad. If it is cold and dry I use a Marmot down bag, if cold and damp a synthetic bag, and if it is summer in the southern mountains, I use a 55 degree REI travel sack. I use a silk liner with either bag. The travel sack is great with a roomy rectangular shape yet packs down to the size of a football or a bit smaller. It is only $59 at REI. With a pad, tent and liner, I can be relatively comfortable down to 40 degrees.
