werdigo
I installed Oxford Heaterz grips and had a little trouble with the throttle side. Still an inch or so out, and concerned about the Superglue that had been liberally applied, I held a piece of wood against the outer end and rapped it with a heavy wrench. It moved in that final inch and seemed (seems) to be fine, and the bar end and Givi handguard are now reinstalled, but I'm finding that the throttle does not return to zero when released. I don't know if the new grip has anything to do with it, but its wire (not yet secured with cable ties) is still hanging loose and surely doesn't hinder twistgrip movement.
Any suggestions? I was surprised several times on yesterday's ride when I released my right hand and there was no change in RPMs.
EDIT: I loosened the Allen screw on the bar end, and the throttle snaps to its closed position. It seems as if the bar end weight is pinching the rubber on the outer end of the heated grip. As I recall, these grips are a bit long for the 700X, even when trimmed to the maximum amount permitted. Mine are totally stock, not trimmed at all. I'm not averse to carving off some of that rubber, staying of course out of the electric region.
EDIT #2: I now believe I simply did not get the heated grip on fully. The white nylon lip on the throttle slider is visible --- the new grip does not fit over it. There's maybe 1/4" of white nylon visible between the grip and the black plastic ring to the brake. I doubt if there should be any gap here. Well, I'm not planning to try to remove and reinstall the throttle-side heated grip. Maybe some kind of thin spacer...
