Cigar Mike
It never occurred to me that there was a motorcycle made in this day and age that rear preload was not adjustable. I did suggest that making small adjustments is the way to go. I would have changed the geometry by raising the forks in the triples to prevent harshness by adding a lot of preload in the rear. But that is just me. There are limits to adjusting your suspension with a wrench. But it does work within those limits.
There is also a difference in how to ride different types of bikes. I have had to learn how to turn a street bike. On bikes with larger front wheels like dual sport bikes, when I lean into a turn I push the bike down keeping my body close to vertical. That is how you make tires stick in the dirt. It has always worked on pavement also with that type of bike. It seems to be the opposite for street/sport type bikes. I am still learning and don't have the confidence I had with the dirt method. I wonder if not changing methods between different types of bikes is also a factor in the pushing that is experienced. I definitely would ride the 690 differently than the NC. And expect them to handle the same obstacles differently. For that matter different tires on the same bike will handle them differently.
