ray
Thanks folks will try
Help needed for mounting the risers on an ABS bike
So.. I've discovered that the brake clip and grommet on my bike is not in the same place as the one in the picture.
It's way up high,... Close to the ignition. I'm working fairly blind with it in that position.
I'm wondering if it is different because the bike is ABS...
Anyone have the same issue... Or better yet, solutions...
Thanks
One to watch out for on an ABS bike or not is the clutch cable. Turn the handle bars both directions and watch the clutch actuator on the right side of the engine. Does it move as you move the handlebars? If it does then readjust the cable. With the 2" rise you need to be careful of how the free play in that cable gets placed. I think that we are just on the edge of using up all the free play in the clutch cable. If I still have the bike when it's time to replace the cable I'll probably get one an inch or so longer.
I have ABS, but for the life of me can't find the clutch cable. Can you post a picture?My thoughts exactly.
Thanks I'll try again tonight!
I never had a problem with the Rox spining on my BMW, but transfering them over to my NCX, discovered that they can rotate unwanted. A few others here have had the same thing.
Tried installing the risers again today. The position that I want to put the bars in (more back than up) makes the brake cable too tight on the NCxa version of the bike. Any thoughts? LBS.. You said yours worked fine... Is your bar directly above where the old one was. It might be that I have more tilted back than you
Sharon
I'm not sure if the handlebar clamp is like this, but on the front forks of older Hondas, where the axle clamped directly on the bottom of the fork cylinders, you have to tighten the front bolts first, then the rears. This is because Honda machines the clamp with a very slight offset or step, where one side of the clamping surface is a little higher than the other. The intent is that the forward bolted surface will be tight and completely flush, and then torquing the rear bolt is what actually applies the clamping force to the axle. If you torque the bolts in the wrong order, or if you put the axle cap on backwards, the bolts themselves will torque down properly, but there will be reduced clamping pressure on the axle.
Again, I'm not exactly sure if this is the case here, but it is a similar mechanical condition, so I wouldn't put it past Honda to use the same philosophy.
Sharon
Sharon
