WingMan71
Did my first mod today. I installed some bar risers. Standard 30mm up and 26mm back units that I bought on Amazon.
When I had the install finished, I didn't like the look of it with the top clamps that came with the kit. Looked like this:
I really like the stock top bar clamp with the Honda emblem on it. So, I decided to toss the top clamps that came with the kit and put the stock bar clamp with the Honda emblem back on. NOPE! Doesn't fit! The hole patterns don't line up! I needed the top and bottom holes in the OEM bar clamp to be about 3/16" farther apart vertically to match the bolt pattern on the bottom half of the bar risers.
I have a small bench top drill press so I thought I'd take a shot at making the existing round holes (5/16") a bit larger (3/8") PLUS make them OVAL, not round, to get the extra separation I needed.
Took me about an hour on the drill press to get the job done. Not perfect, but the holes were enlarged and oval enough to fit the bolt pattern on the bottom section of the bar risers.
Hard to see from the angle of this picture, but they all lined up! Not perfect, but the bolts all dropped into place. Next reinstalled the OEM bar clamp with the Honda emblem.
You can see that the chrome bolt heads are no longer centered in their normal spots, particularly the top two, because I tightened those last. But hey, if you're looking that close, stop it and go riding!
The risers really make a difference on my old-guy back! Plus, I'm much happier with the look now that the OEM Honda bar clamp is back on!
