Heavy-H
Ordered mine.... (centerstand). Then .................. backordered
Does the stand lift the rear wheel up from the ground? A friend of my had installed the main stand from web bike but complain that the stand does not lift the rear wheel up when parked.
Sounds like he got the NC700s stand instead of the NC700x
HONDA : Main stand [08M70MGSJ30]
This the item he got.
Based on what I see there is 2 type one is the domestic model.
Thanks for the clarifications.Both are domestic Japan models as distinguished by the "J" in the part number. The only difference is the language of the instructions. Hard to believe they don't simplify and provide world market instructions and one part number, but they do not. The 0870MGSJ10 (the other one I think you are referring to) is spec'ed for the NC700S or what they are calling the NC700X type LD (possibly "lowered"). The 0870MGSJ30 he ordered should be the correct stand (with Japanese instructions) and should lift the rear wheel clear of the ground. I bought mine from Web!ke and got the correct stand. The one specifically for the US market is 0870MGSA30. At any rate from what I can tell, the -10 is short and -30 is tall. This does not leave out the possibility that the stands are mis-packaged from the supplier or the order is mis-filled from Web!ke Japan. Your friend has discovered (as I often have) the greatest disadvantage of ordering out-of-country.
The two item pictures at Web!ike look the same to me but have different file names...
For comparison, here is the pic from CyclePartsNation for the 0870MGSA30 stand which looks taller to me...
Move thread to How To Section please.
try as I might I cannot get the spring and I'm no weakling.
this the 1st time that a centre stand spring failed to get it on!
I'll take it to the dealer ask them to do it.
I have the Honda original stand installed a few weeks ago... Everything was pretty simple except for the 2 springs... OMG.. My roommate and I was struggling with the springs for a long time, finally with some elbow grease, the spring is on...
One thing I hate about the center stand... I have to put the stock pipe back on or the stand has no place to rest except on the swing arm!!!
took 3 mechanics 15 minutesto fit the big spring this morning...
You need to find new mechanics....or stronger ones.
