NC750x vs NC750s
Forty Two
I am wondering what the differences are between the 750x and 750s. I have Googled and searched this forum but cannot find a clear answer.
The S is styled more like a naked street bike, while the X is styled more like an adventure bike. We have S owners on here that can give more details than I could, but compared to the X, the S:
Sits a little lower. Centerstand and side stand are shorter.
Same engine and similar frame, but different plastic bodywork.
Windscreen and headlight are fork mounted instead of frame mounted.
NC750S
NC750X
melensdad
I am 5'10" so no issues here. I do worry about the weight, though. I am not a fella, so even though I am tall I am not very strong.
Because of the way the engine is mounted, with the cylinders nearly parallel to the ground, and because the fuel tank is under the seat of the bike, the weight is actually carried very low. (low center of gravity). My wife rides a lowered 2016 NC700x.
Forty Two
That is good to know. I do find some bikes very top heavy. I doubt though, if I dropped it I could lift the 750x. Hopefully someone would help me or that is what CAA (AAA) is for. During lessons I...ahem...dropped one of their student bikes and could not lift it back up.
melensdad
My wife has a couple bad disks in her back, she has a very hard time lifting it.
But there is a technique to it that makes it much easier.
Video here => YouTube
dduelin
Lifting a motorcycle is a learned technique and like the video illustrated it’s done using the legs. I’m probably lighter than the woman in the video FWIW and have lower back problems. My ST is 730 lbs. and I’ve righted it by myself several times. As pointed out earlier the NC has a very low center of gravity and “feels” much lighter than it’s actual 500 lbs.
Thanks, that is a great video. I'll have to try that the next time i tip mine over haha :{P
Speaking of tipping your bike over,.... i've used this technique once before at a gas station. it worked slick and the bike was right back up before anyone noticed haha. :{)
YouTube
potter0o
The X should be no issue with your height I would think. You may be able put a leg over one at a local Honda dealer if they have one in stock. In regards to the weight they are virtually the same from what I have seen online. The DCT is a touch heavier.
kpinvt
Premium Member
+25 lbs. IIRC. My 2014 DCT model weighs 503 lbs. stock wet weight.
melensdad
Honda claims 505 pounds for my 2018 DCT, including a full tank of fuel and all needed fluids.
Without the DCT the claim is 478 pounds for a 2018 model year.
So looks like the weights are fairly consistent from generation to generation of these bikes. The new plastics, which started in 2016, or perhaps the new traction control system or updated DCT (Version 3) transmission, seems to have increased the weight by only 2 pounds from 503 to 505.
