hojo
I have a 2014 NC700XD and know that the LED Turn Signal Relay from Luckybike.com will not work on the '14 models (12 and 13 are ok); Lighting - Flash Controller - Honda - Relay - Turn Signal LED - 4 Pin
I went the LED Turn Signal Resistor route and I was able to identify the 3 turn signal wires (turn signal flashing, ground, and running light). I installed the "universal" resistor and discovered it blows the fuse. Here is the resistor: LED Turn Signal Flash Control Resistors.
Notes on install: 1. Again, I know which wires are which. 2. The instructions say to leave the running light wire alone. 3. I made sure that the two wires on one side were connected and not touching, and the wires on the other side of the resistor were not touching, so that they can't touch, arc and short the fuse.
I am waiting a reply back from the store and wonder if anyone here has any thoughts on the possible problem.
Thank you.
Thank you.
