kjang
I received a message back from RIDE-ON.
This is what the messages says :
"Ken,
You do not need to remove the wheel weights. Ride-On will work with your existing wheel weights in place. In a very small percentage of cases, typically less than 10%, you will need to remove the wheel weights as Ride-On will have balanced out a irregularity inside a tire and the wheel weights are now causing a redundant out of balance situation (double compensation). You can also remove the wheel weights altogether if you prefer (nicer, cleaner look). We recommend you to install the severe dose of Ride-On when you are relying on it as the sole source of balancing. The additional amount of product will provide a thicker coating where it is necessary. We do not recommend exceeding the Severe dosage or putting in less than the Regular dosage."
"Ken,
