Nofear2trek
Has anyone else been able to remove that bolt without cutting nor removing the engine mounts? I'm wondering if this one was a fluke of the wrong length bolt that was used during engine assembly at the factory?OK... got my NC back from the mechanic's shop today...
They had to cut the existing bolt in two to get it out. They loosened the engine mounts to give more "wiggle" room, but that was not enough.
The bolt they put in is long enough to securely engage the engine block threads but slightly shorter...and even then it was a tight fit.
So ... that's it. The bolt was too long.
I will try replacing it again in when next the coolant pump fails. I actually stand a chance of doing it with the new (shorter) bolt in place.
If there is a pattern of needing to cut and replace, I may do it before needing to do it in an uncomfortable place in the future.
Ray
