dduelin
The front wheel pulse sensor says "whoa Nellie" to a 1st to 2nd shift it is not turning an appropriate speed compared to the rear wheel.The forward velocity is measured directly from the counter-shaft which is connected directly to the drive sprocket. The PCM also takes other parameters into consideration to determine when to make the appropriate shifts.
Alas, no wheelies, no running up through the gearbox on the center stand, and no way to dyno test a DCT bike.
