Old Can Ride
Step Four:
Remove the right crankcase cover:
First take a rubber mallet and hit the crankcase cover around the edges of the cover, remove the oil dip stick, put the small end of your ratchet into the dip stick hole and pry outward slowly as to not damage anything. The right crankcase cover will pop lose. Remove the two bolts on the inside of the right side case that hold the sensor unit. Remove the right crankcase out of your way for now.
