Nortwestrider
I have decided to wait for the service manual and start over from the beginning.
Live life,be yourself !!!!.
Plate 5 and 7 are different. Yes tighten all springs. Most times the adjustment of the clutch cable attached by the two bolts on the side of the engine case is what needs to be adjusted. Start by leaving the cable real loose, then it will have to make contact. Good Luck!
Ok I got the clutch in and it seems to work good.NOW the bike won't start !!.
It just turns over and over,AND it doesn't matter if I pull in the clutch lever or not !!.
Before it wouldn't turn over unless you pulled in the clutch,now it does !.
Let us know if this works.I did not disconnect the battery and yes I unbolted the pressure sensor
Nortwestrider...any update?
That is an older post. That time he just had that sensor switch that goes in the side casing was upside down. An easy mistake to do. I advise leaving the sensor attached to the side casing, and just wire the side case in place somewhere until you are ready to install the case.
