TheEdge900
I understand, even if everything fits correctly you end up dropping/loosing a screw into the depths of the bike or breaking one of the plastic rivets or stripping the head of a screw because it was too tight or wrong tool was used, all resulting in a trip to the hardware store or bike shop.
The main reason I put off installing farkles is the hassle I know it will be to make if fit/work. Almost every farkle I've installed required machining, filing, bending, painting, a trip to the store for hardware, etc. I really wonder if these aftermarket companies have truly tried to install these products themselves.
Even the big names like Madstad, SW-Motech, and Givi have products that don't fit right.
I'm currently fussing with the SW-Motech side case brackets. First, the rubber bumpers stuck out so far the bags wouldn't snap on. The rear cross piece bracket needed new hardware to properly install. Now it looks like I need to file slotted holes in the footrest bracket plates to get the side brackets in place without having to bend the whole fender/taillight assembly down to attain alignment.
Even the ADVMonster aux light clamps required major filing to get the clamps to grip tightly. However, Kudos to Rox Risers as that was the one piece that fit without mods.
