Aprilia Tuono V4 shock
kokomoto
East Tennessee
I installed a 2012 Tuono V4 rear shock on my 2020 NC750X. I replaced the OEM spring with an 800 lb Hyperpro 186a0800 spring. It's a 6" spring that went on without much fuss. I also installed an NTA3648 needle thrust bearing with fitted washers to make preload adjustments easier. I have 10mm of preload on it without checking the sag, and it seems to be in the ballpark. After returning from about a 1,600 mile round trip to Florida, I can say that it is definitely an improvement. The rear certainly rides much smoother.
The total cost was under $200.
Shock - $85
Hyperco Spring - $80
Bearing - $11
NTA3648 Needle Thrust Bearing
Shock - $85
Bearing - $11
Good idea on the needle thrust bearing. Never would have thought about that. Appreciate it.
