Battery install
Outrider1
Sussex
Actually what I'm needing to do is put a pig tail on for the battery tender. 2018 nc750x dct.
My question is this: can the battery be slid out so you can disconnect from the terminals? There doesn't seem to be a wiggle room at all. I don't want to pull on the battery and do any damage.
Jt105
Michigan, USA
I put my battery tender pig tail on without removing the battery. You just need to reach in there and manipulate the wires a bit and you can slide the battery out enough to get to the terminals.
JT
Outrider1
Sussex
JT
Thank you! I'll try to work the battery out a bit.
That could have been designed with an additional 3" and made life a bit easier.
