dakotamiles
I have been riding my NC700X off and on since May - it sits for two weeks then I ride it either all day or 100 miles, then it sits again for another week or so. (Lucky me, I don't have to commute!) It's a 2012 model but I bought it new a year ago. I stored the battery inside last winter, connected to a trickle charger for part of the time. With the bike being this new I don't expect a lot of problems.
So I was pretty surprised when I went to ride it yesterday and the battery was flat. No lights, no nothing. The battery bolts were tight. I removed the battery, charged it up and it seems to be okay. The bike starts and runs just as nice as ever. I measured voltages of the battery after not - full charging - 12.7, during starting - 10 or 11 V, and while it was idling in the driveway - about 13.5 - 14 V. So the charging circuit seems to be working. Sitting there for a few hours, the battery voltage is gradually dropping to 12.5V at this point. I think the voltage can drop slightly as a battery sits after being charged, but I hope it doesn't keep going down. I'll report on the voltage after a day or two.
But - how could this happen?
I can think of two possibilities:
1) The last time I turned the key I didn't start the engine, I was just looking at the gauges for about 30 seconds. Then I turned it back off again. Four days later, there was no juice in the battery. Did a relay turn on and then not turn off again?? Should I make sure I start the engine when I turn the key on??
2) Last fall I installed the official Honda heated grips. But I haven't used them at all this summer and I believe (without knowing the details of the wiring) that they are connected to the switched power. They don't come on unless the ignition is on. I don't think I even touched the grips that time I turned the key.
Is there unswitched power somewhere on the bike? While I had the battery out for charging I checked with an ohmmeter and detected very high electrical resistance. But I know that's different than powering the bike up with 12 volts. The clock at least seems to need power continuously.
If anyone else has had an almost new battery die unexpectedly I'd like to know.
