Sorry just measured them 22mm, definitely not the chain which BTW is brand new.Without a real reference for size, could it be drive chain O rings?
41mm fork caps take 22mm o-rings? Thinking not.The o-rings under the fork caps are ~ 22mm. Not sure why you would have 3 of them.
Had the valve cover off? Are there o-rings on the valve cover bolts?Over a number of weeks I have found these broken “O” rings under my bike, one at a time. Can anyone tell me where they may come from as I’m at a loss??
Had the covers off 1 year ago. Not O rings they are sort of rubberised washers.Had the valve cover off? Are there o-rings on the valve cover bolts?
Item #22. Again, should only be 2 but 21.7mm is pretty close.
The 91356-KF0-003?
That’s a possibility as it has just been in the dealers for an ecu fault, with the diagnostics saying speed sensor fault. The O rings may have been replaced and the old ones left in the engine.There are 3 "speed sensors" on the back of the crankcase that have an o-ring seal. #30 in the diagram. I cannot find a dimension for the o-ring.
Yes I agree with you I had actually thought of it myself. Please see the above post which seems to be a definite possibility.Didn't the OP have his bike worked on at the dealer for DCT issues recently? Maybe the dealer 'lost' them while diagnosing the issue and they just now fell out?
Maybe SUV is on to something. I am out of ideas.
But why would they just happen to fall out when it was parked with no outside force? I am going to go with SUV.Didn't the OP have his bike worked on at the dealer for DCT issues recently? Maybe the dealer 'lost' them while diagnosing the issue and they just now fell out?
Nobody has been to my house recently and definitely not in the garage. My best friend and riding buddy died about 3 years ago, not bike related so now mostly ride on my own.But why would they just happen to fall out when it was parked with no outside force? I am going to go with SUV.
