dakotamiles
I appreciate the various threads here about chain maintenance. Particularly since I was doing it wrong with my original chain! It was starting to develop tight links after 8k miles due to solvent abuse - I had been cleaning it with gasoline because I didn't think enough about what I should use. I thought I knew. Hah. Today I just replaced the chain with a new RK 520 XSO series chain. New sprockets too!
The new chain is covered with sticky white grease so I wiped the bulk of the grease off of the sides and outer edge of the links.
I presume that grease will be okay for awhile, like maybe 100 miles or more, although it's going to collect dirt more quickly than the chain lube I use. How soon do y'all start lubing your chain? Do you lube the chain when you first install it? Or do you let the grease kind of collect dirt first? How do you decide? Does it matter?
By the way, I also just learned about the Grease Ninja special chain lube tool. It seems like a really good idea but I haven't used it yet.
It rides on the chain and deposits the lube where you want it. It looks like this:
Here are the two holes, strategically placed:
