wozza
- Joined
- Sep 8, 2012
- Messages
- 934
- Reaction score
- 1
- Points
- 0
- Location
- Costa Del Morecambe, England
The below was posted on the UK forum by user name 'Old Man', so any credit for this must go to him.
I thought the below information is of enough importance I thought I would share.
I don't know how correct the info is and I haven't tried it, so that is my disclaimer.
I'm not particularly technically minded, so comments and thoughts from more skilled members would be appreciated.
I hope the below info may be of use to some of you guys.
Posted 10 July 2013 - 11:27 PM
So I’ve been doing some reading in the quest to better my bike in regards to its smoothness.
I was out at the weekend with a good friend and although a fantastic ride I felt that the bike wasn’t nice to ride and found it harder to ride smoothly though villages and slow tracks when in 1st and 2nd.
Apparently as part of the prep before the dealer hands over the keys, the mechanic resets the ECU starts the bike and lets it idle for around 15 minutes until the fan cuts in. In the 15 minutes the ECU creates a base map using all the info gathered from the O2, water temperature and possibly other sensors.
I have added a number of mods including a DNA air filter and a Beowulf end can thus changing the airflow in the exhaust. Now I was under the impression that the ECU would adapt to this change and compensate; but it seems that it is restricted by its already formed base map created on day one.
Please correct me if I am way off the mark.
I reset mine tonight and went for a ride and am very pleased with the results.
Smoother throttle response, pulls from much lower in the rev band in all gears and 6th is much more usable. Also seems to sound better.
This is what I did.
1.Completely disconnected the battery for 24h (my reading sources state 10 minutes to half an hour) I wanted to me sure.
2.Turn the key to on to get rid of any held power for about 30 seconds (probable not needed).
3.Reconnect Battery (make sure all other electrics are off)
4.Turn key to on
5.Start bike without touching the throttle.
6.Leave to idle (DO NOT TOUCH THE THROTTLE) for around 15 minutes until the fan kicks in (mine took 16 minutes).
7.Hit the kill switch.
8.Turn off the ignition.
9.Now you’re done.
If you do decide to give it a go please let me know what you think.
Old Man
This is what I did.
4.Turn key to on
9.Now you’re done.
Old Man
