n30r3l0ad3d
I bought a R&G rear hugger the other day and got around to installing it this weekend. To my shock, it will not work on my NC. Here's why:
1) The screw they give you to hold the stock philips screw is the wrong thread (thread types do not match). You will strip the head off the new screw if you try to thread it in.
2) The enclosed clamps to hold your rear brake line are too small. Not sure if it's a 2013 model change, but my brake line has an exterior hose around it to protect it from the elements. They enclose 2 zip ties for ABS models, which mine does not have.
3) The left side of the hugger barely clears the chain, and I mean barely. The alignment of the hugger was spot on, but when you tried to get it in the correct position, the chain would in fact HIT the side of the hugger. I put a chain alignment tool just to make sure, and it's dead center.
I am really bummed. I tried everything to make this work, but it will not work. I will call tomorrow and see about either getting my money back or a replacement.
Edit. The place I ordered it from was very cool about taking it back, and are working on a solution for me.
