Cigar Mike
I like to take the bikes with me when I take my travel out for a week or more at time. That used to mean loading up the DS bikes in the back of the truck. The 350# XR650L could be a chore when the 1ton Dodge truck is on flat ground. The tail gate is up pretty high. I was concerned that pushing the 470 NC or even using the motor might be a challenge. The CB500X weighs in at 430# and I hate to admit it but I was afraid if either one started to tip while I was stepping into the truck I might drop it.
I decided the old man way to do it would be to use a winch. I bought a ATV winch from HF and fabricated a mounting bracket to mount the winch to the bed of the truck. I tried it out today and it does work and is pretty simple. Being able to just concentrate on balancing the bike without having to use throttle or brake does make it easy.
The winch is remote controlled and is easy to use. I bought some rope and made two short rope slings to connect to the forks as a pulling point. I use a small battery set in an ammo box to connect to the winch. All the parts needed to connect the winch to the truck and operate the winch and are in the box as well.
We will going to Utah to see family soon and want to take the NC and CB this trip instead of the DS bikes.
This is what sits in the bed when not in use.
Winch bolts to those rails and battery in ammo box sits right behind it.
The snatch block connects on the eyebolts and then the cable can run back towards the back of the truck close to the centerline of where the bike is to be parked.
The box with battery, charger and controller.
Rope slings are attached here to winch bike into truck. I forget what the rope is made of exactly. But it is very soft and strong.
I do like riding the bike for multiday trips and camping in a tent is fine as well. But I like this and have been doing it for 45 years.
