Mgajohnson
How many Km's or Miles should someone expect the clutch to last under normal on the road riding?
That's good to hear. I was wondering the same thing. I've been practicing going slow and keeping my balance. You have to slip the clutch a bit for it.
I've gotten into the habit of using the Sport mode on my NCXD thinking it would create a LOT less wear & tear on the DCT clutches by shifting way less often, especially in stop & go traffic. My main concern was not the actual clutch so much as the DCT shifting mechanism itself.
I noticed that the clutch could be slipping.
At the normal half clutch position, the bike doesn't want to pull.
Looks like another nail in the coffin for the NC700X.
Bike is at only 15500km. Maybe it is something else?
Sent from my LG-D955 using Tapatalk
Seriously do you think it is just the free play adjustment of the clutch cable?It sure sounds like you're trying hard to justify replacing the NC. If you want it to be the last nail, then it can and will be. Otherwise you can probably just adjust the cable and ride it another 100000 km.
If ridden the in dirt often, then about 50,000 miles per clutch. Make sure to replace the springs also. Fairly easy do it yourself job.
