ChilliRider
A colleague of mine, Farhad Dastur co-authored a paper in 2014 "Motorcyclist’s lane position as a factor in right-of-way violation
collisions: A driving simulator study".
Here is the abstract (the pdf is too big to upload but send me a pm if you are interested and I will send the paper along):
A driver turning left and failing to notice an oncoming motorcyclist until too late is the most common
cause of motorcycle collisions. Consequently, much previous research has focused on motorcycle properties,
such as size, shape, and color to explain its inconspicuousness. However, collision statistics remain
largely unchanged, suggesting that the issue may not be related solely to the motorcycle’s static properties.
In the present study, we examined a different characteristic of the motorcycle, namely its trajectory
of approach. Seventeen participants faced oncoming traffic in a high-fidelity driving simulator and indicated
when gaps were safe enough for them to turn left at an intersection. We manipulated the size of the
gaps and the type of oncoming vehicle over 135 trials, with gap sizes varying from 3 to 5 s, and vehicles
consisting of either a car, a motorcycle in the left-of-lane position, or a motorcycle in the right-of-lane
position. Our results show that drivers are more likely to turn in front of an oncoming motorcycle when
it travels in the left-of-lane position than when it travels in the right-of-lane position.
I was taught "left side or right, tight to the white", meaning on a two-lane road the riding position is on the left side of the lane (avoiding potholes/road irregularities excepted). The study suggests that is the most dangerous position to be in approaching an intersection with a driver waiting to make a left turn from the opposite direction.
The problem with the "right side" position is that car drivers approaching a main road from a side street are more likely to not see you. The problem with changing lane position approaching an intersection may be giving the 'left turner' the impression you are going to make a right turn (if they are paying attention).
I think I will just invest in more lights... thoughts?
