Riffraft
Was wondering if anyone has found any handlebar risers that fit the NC700X yet?
I was thinking of trying some generic Rox pivoting risers such as these:
Pivoting Risers 2"x7/8"x7/8" Black Anodized (1R-P2SS) | Rox Speed FX
But I think my body is finally getting used to the seating position.
I don't know if they will work on the 700x or not either, but they have a nice feature with allowing both rise and rear adjustment. You can go to [+Add a motorcycle] on this site and plug in NC700x and your physical dimensions, then with [customize] you can see the effect of both adjustments (as well as several more)...
Motorcycle Ergonomics
There is a very short hose length from the reservoir to the first connecting joint. Those of us who would like to "raise the bar" and maybe drop it back a bit, are going to be very indebted to the person who comes up with a solution to this problem.
These are standard bars, and most any bar riser will fit (the proper Rox Risers would be ideal). But it's all academic if we can't find a way to lengthen the necessary hoses and cables.
I'm actually looking for a 2' riser. If it isn't available I may have to make it in my shop.
I have 2 inch ROX risers installed on my NCX. I have not had any problems with binding. I have also installed 1 3/8 lowering links
Good to hear, thanks!
Brand of lowering links? Did you have to shorten sidestand for trustworthy stability?
