spets
Draco, did you mess around with any of the spacers with the cyclops bulb? Curious if that beam dropoff to the right can be corrected with spacers.
Brillot, can you attest to the reliability of your recommended bulb?
[emoji1] I totally scored on the garage. It's almost long enough for 2 cars, but it is perfect for 1 car, the NC, and plenty of workspace.Wow, I wish the inside of my garage was more than 20' long. Mine is 20' door to back wall. I would have to take out the back wall and extend the garage another 6' to get the front of my bike 20' away from the backside of the door.
I didn't get any spacers. I will recheck the box and contact Cyclops if needed.Draco, did you mess around with any of the spacers with the cyclops bulb? Curious if that beam dropoff to the right can be corrected with spacers.
I went on a short test ride tonight. I actually did 2: one with the filter, and one without. In the NC reflector, the light with the filter is just too dim. It's OK on the high beam, but not the low. The unfiltered bulb is much better. I don't think low beam is significantly brighter than stock. The high beam is way better than stock. The light isn't too blue in my opinion, and I wasn't flashed at all during either ride.
The biggest benefit will be the decreased power draw. Eventually, I'll get some aux lights to really brighten up the road.
I was not flashed at all. The cutoff is almost exactly where the stock cutoff was (see pics of garage door)This means that you have to adjust your headlight aim, the beam in Low Beam is too high...
Typically after installing any LED Conversion into a headlight will require adjustment.
Right of handlebars the adjustment screw can be located looking down.
Looking up from the bottom side.
I recommend using a Phillips screwdriver directly on the head of the screw, not using the cog setup as described in the Shop Manual.
If you would like to save a few watts on the electrical system, then yes. It will probably add a little visibility to other drivers because of the color temperature difference. Less likely to blend with car lights in the background, although more and more cars are equipped with cool-colored LEDs and HIDs so...Would you recommend just buying the auxiliary lights from the get go?
These do not use a fan just a heat sink and are shorter.
2X H4 9003 LED Headlight CREE 60W 6000LM 6000K HID White High Low Beam DIY Bulb | eBay
