draco_1967
Hope you have a speedy recovery!
Item (7) in my update. The deflectors are one of my favorites as well, as they involve a bit of ingenuity and not just pulling out a Visa card. I haven't used the Honda deflectors, so I can't compare to them, but mine do a good job of deflecting wind from the lower body. My measure is the amount of wind fluttering of a pair of pants before and after. I generally ride in protective pants that don't flutter, but I did ride a before and after in khakis to test the difference, and it is significant. I also have not done a ride yet in hard rain, but I expect similar improvements.
I toyed around with how big to make them, but I am satisfied with the result both aesthetically and functionally. The cost was about $25 in materials. As far as learnings, I could have used tinted acrylic (not sure I would prefer it) and I could have "gotten away" with 3/16 instead of 1/4. Since I also needed them to perform duty as driving light mounts, I went heavy. The only downside was the need to heat them from both sides when forming the radii. I could have possibly clamped to the bars instead of drilling them, though they are quite heavy and I don't think I compromised them with four 1/4 inch holes where I placed them.
Thank for your interest. Let me know if I can provide any further info.
I would be interested in buying a set of these if you're so inclined in the future, perhaps an improved, clamp-on version that will accommodate the HondaLine fog lamps.
...and get well soon.
Unfortunately I have hit a setback Lane. I have torn a tendon on my left bicep from over-lifting and am going to have to have surgery to fix it. I was told that I will have to wear a brace and limit the use of it for six weeks until I finish physical therapy. So, I will have a new Russell seat and cannot ride my bike. I normally do an annual ride to Stockton, AL on the last week-end of the year. This year it is December 30th. That might squeak in with the completion of my PT regimen.
But that is only a short ride. The next really big trip is the maritime provinces and Labrador next summer. I will take the NC instead of the beemer.
Lee,
Sorry to hear of your problem. Unbelievably I'm having knee surgery tommorrow morning. I should be good to go before we leave for Fl in Dec. Good luck to you.
Thanks, but I don't think I want to get into the manufacturing biz again. I can't get all of my own stuff done - especially now that I am going to be the one-armed wrong-handed gimp for the rest of the year. The fabrication is not difficult. And I have already figured out a clamp style mounting system. There are a lot of folks with the condition called drill-o-phobia. I guess I am a drillophile. When I bought my new Silverado, the next day the interior was out (including the dashboard and headliner) and I was chassis-punching a hole in the roof for the 2M HAM antenna and cell phone booster antenna. It doesn't bother me a twit to chuck a bit. My wife just shakes her head and won't let me near her Suburban with a loaded drill..
It has been a very effective addition to the bike though and could easily be held low enough to accommodate the Honda light bar, even though it provides a perfect mounting place for the lights and could save you the cost of the bar. One thing though, I am not sure that you can use the Honda light bar with the Givi engine guards. My system is built around the Givi bars.
...please share you idea for a clamp-on system...forgot about the engine guards.
10) Rigid Industries Dually LED Spot Lights: I am very pleased with these, especially when used with the IQ-170 controller. I have a control switch which cycles them between 20 % and 50% brilliance. When the high beam is triggered, the Duallys go to 100% brilliance. However, with the HID headlight being what it is, I cannot even tell whether the Duallys are on or off. I am sure they add significantly to "conspicuity" and they are indeed keepers, but if your only objective is to light the road, then all you need is the 55w HID headlight and nothing else. It just plain works.
11) Strobes-n-More Amber LED Marker Lights: These do a great job. The amber color and the spatial separation from the headlight both add to conspicuity. As alternated turns, there is no doubt what the idiot on the motorcycle is about to do.
12) Whelen and Custom Dynamics rear lights: These are ambulance quality lights. They work very well - even off-center where some LED's have problems.
I think fogs are not much use, other than conspicuity, but spots aimed a bit wide do help with the peripheral visibility. Right now I have two D2 spots and two D2 Duallys and together they add quite a bit. I have never heard of the photon blaster.
D2 with 6 LEDs? Wow... I thought spots aim narrower than the fog, which generally has wider/flood pattern.
Do you think it is odd configuration if I have one spot (LEFT) and one wide (RIGHT) lens?
I plan to get the Dually (4 LED), what configuration (spot or flood) would you recommend? Or I better off don't waste my money if not having D2 (6 LEDs).
