hojo
It sounds like the majority of those that manually oil their chain, do so every 500 miles. I know that one way you can tell if you are setting the drip rate too high is either by oil on the rear tire/rim and/or oil on the floor (dripping off the chain while sitting). Okay, so that makes perfect sense, but what is the LEAST amount of oil to drip onto the chain, and the only way I can collectively monitor this is how quickly or slowly, the oiler needs to be refilled.
I'll start first with my thoughts: If I manually spray the chain every 500 miles, should the automatic oiler drip rate be set such that the oiler bottle needs to be refilled every 500 miles? In theory this sounds about right, however, if I have to stop and fill the oiler every 500 miles (and now I have to carry extra oil), why not just stop and spray the chain every 500 miles (I know, one nice thing about the oiler is that it drips oil onto the chain while it is raining).
I'm pretty sure that when I manually spray oil onto the chain every 500 miles, I am NOT spraying the same amount of oil that the automatic oiler can hold, so I'm thinking that the drip rate shouldn't be so high that the oiler needs to be filled every 500 miles. Maybe a reasonable drip rate for the automatic oiler is such that it doesn't need to be filled until 1,000 miles have been driven. That makes a long day in the saddle much more reasonable so that you don't have to worry about stopping until the end of the day to fill the oiler.
Then there is the middle of the road; set the drip rate for 500 miles, then if you manually oil your chain, couldn't you in theory, go another 500 miles (now 1,000 miles into a ride) without either spraying the chain or putting oil into the oiler? My concern with this method, is that at 1,000 miles when you fill the oiler, it won't completely lube the chain for many, many miles down the road. On the flip side, spraying the chain would give instant complete lube, but then start to wear off later rather than sooner.
I would like to hear how others are setting their drip rates on the oiler.
