ShipofFools
Twice last week, while trying to leave work, my bike would not start. I got a jump start both times from a coworker but this signaled to me that something was wrong. I took the battery to two place to have it checked and both places said it was fine and held a charge. Clearly this was not the case.
I bought a new battery to remedy this situation and am glad to report that it is working fine. The reason for this post is as follows: how long should the stock battery reasonably last? I ride it regularly, and when there's an extended wet or cold spell, or when I'm out of town, I keep it plugged into a battery tender. My Honda Civic lasted on the original battery for seven years, so I guess I expected the same out of the bike. Does heat have anything to do with it?
Also, to anyone who has gotten a replacement battery, have you had any problems installing it? More specifically, connecting the bolts and nuts on the terminals. I struggled with the installation because the damn nut refused to stay still for the bolt. It doesn't help that the positive terminal cable is very short. I want to reattach the battery tender cable eventually but I'm afraid I'll have the same problem with the nuts. Is there an easier way to install the cables?
Sent from my Nexus 4 using Tapatalk
