Barkbuster Storm
Outrider1
Sussex
2018 model year with DCT. Any modifications needed to mount these, if so what?
Found information on earlier years and not sure if it applies.
DavidH
Johannesburg, South Africa
I have these fitted to the same model.
I was unable to remove the standard in-bar anchor for the end-weights. The You Tube videos for this task were for the older models, did not work for the newer model. I spent hours on this and eventually gave up.
I left the in-bar anchors in and fitted the Barkbusters at the end of the end-weights. This required some modification to get it to fit nicely.
If you can get the standard in-bar anchors out, you should not have a problem.
See attached pictures
Outrider1
Sussex
thanks for the information
