woppyvac
I've owned a few bikes and for the most part have ridden them all the same in regards to how I shift, etc. In the past and when not needed, I typically only used the clutch for coming out of 1st gear and down shifting. However, I've found the sweet spot on the 700x to be a tricky for shifting into second gear without using the clutch. I've resigned to clutching shifts on 1st & 2nd gear and then kicking up from there. I wonder if the low rev engine and low shift points are the culprit? Anywho, just seeing if I'm the only one whose noticed this as well.
