Experience the Thrill of 3 Wheels On The 2023 Can-Am Ryker Sport
The 2023 Can-Am lineup includes the middle level Ryker, the Sport. At the heart of the Ryker Sport is a fuel injected, three-cylinder, liquid-cooled Rotax 900 ACE engine. The Ryker sport pumps out an impressive 82 horsepower with 58.3 ft-lb of torque. The Ryker’s Automatic (CVT) transmission with a reverse function makes it easy to handle.
The Ryker Sport’s double-wishbone front suspension and mono-swing arm rear suspension ensure a comfortable ride. The front shock, a KYB HPG with preload adjustment, offers a travel of 6.34 inches, while the rear shock gives you 6.65 inches of travel.
Braking on the Ryker Sport is addressed by the hydraulic 3-wheel brake system. With 270mm discs with Nissin 2-piston floating calipers at the front and a 220mm disc with a 1-piston floating caliper at the rear. Also, the Anti-Lock Braking System (ABS) adds another layer of safety.
The seat height is a comfortable 24.7 inches, offering a low center of gravity that’s ideal for handling and control.
Can-Am is known for its technology and the Ryker Sport doesn’t disappoint. It sports a 4.5-inch digital display. It shows all the key information: speedometer, tachometer, odometer, trips, distance to empty, engine lights, fuel gauge, clock, and even your mode – ECO or Sport. The Ryker Sport’s design includes standout features like dual halogen headlamps, integrated LED lights on the front fenders, a full rear fender, and sport comfort seat. Rounding out the technology package, it comes equipped with cruise control and a Sport mode.
The 2023 Can-Am Ryker Sport starts at $11,899 USD / $15,099 USD (CAD)
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Can-Am Ryker Sport in one place.
Motorcycle Overview
- Price: $11,899 USD / $15,099 USD (CAD)
- Touring equipment added
- 47 Gallon storage capacity
- Premium LED headlights, 7.8” screen
- BRP 6 speaker audio
- Engine: 900 cc Rotax in-line 3 cylinders liquid-cooled
- Power: 82 horsepower
- Torque: 58.3 lb-ft
- Weight: 642 lbs (291 kgs)
- Seat Height: 24.7 inches (629 mm)
2023 Can-Am Ryker Sport Specifications
Engine | |
Engine displacement | 900 cc |
Type | Rotax® 900 ACE |
Bore & stroke | 2.9 x 2.7 in. (74 x 69.7 mm) |
Power | 82 hp (61.1 kW) @ 8000 RPM |
Torque | 58.3 ft-lb (79.1 Nm) @ 6500 RPM |
Lubrication | |
Drivetrain | |
Transmission | Automatic (CVT) with reverse function |
Type | Automatic (CVT) with reverse function |
Gears | |
Chassis | |
Suspension Front | Double wishbone |
Suspension Rear | Multi-link – mono swing arm |
Brakes Front | 270 mm discs with Nissin 2-piston floating calipers |
Brakes Rear | 220 mm disc, 1-piston floating caliper |
Tires Front | MC 145/60R16 66T |
Tires Rear | MC 205/45R15 81T |
Fuel Tank Capacity | 5.28 gal (20 L) |
Color | |
Safety and Security | |
ABS | Anti-lock Braking System |
Anti-theft system | |
HHC | Hill Hold Control |
Dimensions | |
L x W x H | 92.6 x 59.9 x 42.2 in. (2,352 x 1,522 x 1,073 mm) |
Wheelbase | 67.3 in. (1,709 mm) |
Seat height | 24.7 in. (629 mm) |
Ground clearance | 4.0 in. (101 mm) |
Dry weight | 642 lb (291 kg) |
Curb Weight | |
Warranty | |
Warranty | 2-year BRP Limited Warranty with 2-year roadside assistance |
Extension | B.E.S.T. extended service term available from 12 to 36 months. |
2023 Can-Am Ryker Sport Features
Features
2 halogen headlamps (55 W)
Front fenders with integrated LED lights
Dual USB port
Glove box
Full rear fender
Sport comfort seat
MAX Mount Structure
Sport style trims and finishes
Cruise control
Rear KYB HPG shock with remote reservoir 4-position compression adjustable damping
Sport mode
2023 Can-Am Ryker Sport Photos
2023 Can-Am Ryker Sport Videos
2023 Can-Am Ryker Sport Review by Arch417 Powersports:
2023 Can-Am Spyder Ryker Sport Review by Blackphoenix Entertainment:
Can-Am Websites
The post 2023 Can-Am Ryker Sport [Specs, Features, Photos] appeared first on webBikeWorld.
