2023 Can-Am Ryker [Specs, Features, Photos]
Redefining Riding On The 2023 Can-Am Ryker
The Can-Am Ryker represents a unique offering in the motorcycle world and stands out with a long list of features and distinct look that turns heads wherever they go. Starting with the stock look, there are several unique color choices and new accessories for 2023 allowing you to quickly change the look of your ride and get back on the road.
The 2023 Can-Am lineup includes the base Ryker model, Ryker Sport, and Ryker Rally, each designed to conquer different terrains and satiate the adventurer in you. Whether it’s asphalt, concrete, or dirt, the Can-Am Ryker family has a ride to help you explore The Ryker is equipped with a powerful and efficient Rotax engine, available in two variants – the 2-cylinder Rotax 600 ACE with 50 horsepower and the 3-cylinder Rotax 900 ACE with 82 horsepower. The Ryker comes with an automatic transmission, which provides an effortless driving experience. The “twist and ride” feature ensures great fuel efficiency, giving you more time to admire the scenery and enjoy the adventures that lie ahead. For convenience, it also includes a reverse gear!
An important aspect that sets the Ryker apart is its commitment to rider comfort with the tool-less rider seating adjustment and ergonomic features like adjustable foot pegs, brake pedal, and handlebar, the Ryker brings the open road within reach of more riders.
The Can-Am Ryker’s driveshaft technology provides a smooth and maintenance-free riding experience giving riders more time to enjoy their ride and less time spent on upkeep. For safety and stability on the road, the Ryker features a suite of safety features from BOSCH including stability control, anti-lock brakes (ABS), and traction control.
The SACHS suspension, both front and rear, helps the rider maintain control and extract the most performance out of the Ryker. It includes twin-tube coil-over shocks, while the rear has SACHS twin-tube coil-over shocks with preload adjustments
The 2023 Can-Am Ryker starts at $8,999 USD / $11,399 USD (CAD)
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Can-Am Ryker in one place.
2023 Can-Am Ryker2023 Can-Am Ryker
Motorcycle Overview​
  • Price: $8,999 USD / $11,399 USD (CAD)
    • Powerful Rotax engine
    • Twist and go transmission
    • Easy Customization
    • Multiple riding modes
  • Engine: 600 cc in-line 2 cylinder, liquid cooled / 900 cc Rotax in-line 3 cylinders liquid-cooled
  • Power: 50/82 horsepower
  • Torque: 36.7/58.3 lb-ft
  • Weight: 594 lbs (270)/616 lbs (280 kgs)
  • Seat Height: 23.5 inches (597 mm)
2023 Can-Am Ryker Specifications​
Engine​
Engine displacement
600 cc
Type
Rotax® 600 ACE
in-line 2 cylinders, liquid-cooled with electronic fuel injection and electronic throttle control
Bore & stroke
2.9 x 2.7 in. (74 x 69.7 mm)
Power
50 hp (37.3 kW) @ 7300 RPM
Torque36.7 ft-lb (49.7 Nm) @ 6000 RPM
Lubrication
Drivetrain​
TransmissionAutomatic (CVT) with reverse function
TypeAutomatic (CVT) with reverse function
Gears
Chassis​
Suspension FrontDouble wishbone
Suspension RearMulti-link – mono swing arm
Brakes Front270 mm discs with Nissin 2-piston floating calipers
Brakes Rear
220 mm disc, 1-piston floating caliper
Tires FrontMC 145/60R16 66T
Tires Rear
MC 205/45R16 77T
Fuel Tank Capacity5.28 gal (20 L)
Color
Safety and Security​
ABSAnti-lock Braking System
Anti-theft system
HHCHill Hold Control
Dimensions​
L x W x H
92.6 x 59.9 x 41.9 in. (2,352 x 1,522 x 1,063 mm)
Wheelbase67.3 in. (1,709 mm)
Seat height 23.6 in. (599 mm)
Ground clearance
3.8 in. (97 mm)
Dry weight594 lb (270 kg)
Curb Weight
Warranty​
Warranty
2-year BRP Limited Warranty with 2-year roadside assistance
ExtensionB.E.S.T. extended service term available from 12 to 36 months.
2023 Can-Am Ryker Features​
Features​
2 halogen headlamps (55 W)
Front fenders with integrated LED lights
Dual USB port
Glove box
Adaptive foam waterproof seat
2023 Can-Am Ryker Photos​
2023 Can-Am Ryker 2023 Can-Am Ryker 2023 Can-Am Ryker 2023 Can-Am Ryker
2023 Can-Am Ryker Videos​
2023 Can-Am Ryker Sport Review by Fast Lane TV:
2023 Can-Am Ryker Sport Review by Arch417 Powersports:
Can-Am Websites​
The post 2023 Can-Am Ryker [Specs, Features, Photos] appeared first on webBikeWorld.
