luckedoggs
Is there an easy way to check the relays or wiring? My 12v OEM socket is not working. I checked the fuses and they look good.
That I did not realize. I checked the main fuse box. Do I need to remove the left panel to get at the fuse?
The reason why mine still don't work for now 1 year, is because I have to remove this F*@K*@G panel ! GRrrrrrrrrrrrrr...I'Mm in holiday for 3 weeks and will replace it with a 3 amps just like silverhound suggest.That I did not realize. I checked the main fuse box. Do I need to remove the left panel to get at the fuse?
3 amp fuse still small for a tire inflator. My Slime motorcycle compressor is rated at 15 amps. Best direct to battery with own fuse. The wiring in the accessory is light for that load and even if heavier wire you probably don't want a big fuse for other items in your accessory outlet such as charging a phone.
Oh geez...on July 22nd I spent over an hour trying to find the stinking fuse for the thing. I followed and followed the wire taking panel after panel off and finally. I cut the fuse wire, added more wire, and relocated the location of the fuse to under the battery so I can get to it easier.
