Torque specs
  • <i class="fa--xf fal fa-check "><svg xmlns="http://www.w3.org/2000/svg" role="img" aria-hidden="true" ><use href="/data/local/icons/light.svg?v=1750516829#check"></use></svg></i> Discussion starter Discussion starter maxwellian
  • Start date Start date
At least for me, it's much easier to have two short lists posted above my workbench. One list has the common torque for 6 mm, 8mm, and 10 mm bolts/nut. The other list has torque for axle nuts & fork pinch bolts, handlebar clamps, brake mounts and triple clamp. Most of the other stuff you'd never use.
Yeah, I pretty much just picked out the stuff for doing brakes, chains, tires and valve adustments
maxwellian: Thanks so much for sharing the doc!
D_SC: My Honda service manual stickered as 2012-2015 says the steering stem nut spec is 103 nm / 76 ftlb.
I made a google doc of the more common maintenance items' torque specs so I could have it on my phone. Much easier to clean the grease off of than a paper manual :D
Can't figure out an easy way to embed it here, but here's a link
Torque
I’ve done the same thing in a notebook I keep for bike maintenance. But I like your spreadsheet much better. :cool:
Torque
Thanks Max for the doc and thanks Red Rider for bumping it up today. I am torquing the sprockets tomorrow and now I don't need to go look them up.
I have those torque figures printed and taped to the hood for the flourescent light fixture above my workbench. Also have another "note" with mileage/dates for last oil change, new front tire, new rear tire, and brake pad replacement. ;)
Does anyone happen to have the tightening torque for the ABS sensors for me?
