2023 Honda CBR1000RR [Specs, Features, Photos]
The 2023 Honda CBR1000RR: Liter Bike Legend
Among the big Japanese Manufacturers, Honda has consistently shown they know how to build a legendary liter bike. The last major revision to the CBR1000RR came in 2021, and there are no significant changes to the bike for the 2023 model lineup. Once again the Canadian market will not get to enjoy this bike, it is not being offered in that market.
The CBR1000RR is equipped with high-compression pistons and can rev like no other flat-plane inline-four. The throttle-by-wire system is seamlessly integrated with Honda Selectable Torque Control, providing riders with the flexibility to select from three different engine power-delivery modes, plus two customizable power modes, allowing riders to tailor their riding experience to their individual preferences.
Naturally, The Honda design team has fitted a beautiful and easy-to-read TFT display, bright LED lighting, and all the tech one expects from a modern superbike. What is still quite odd is the ABS braking is actually still an option. Either way, the CBR1000RR remains an epic liter bike choice.
The 2023 Honda CBR1000RR starts at $ 16,599 USD / $ N/A CAD.
On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2023 Honda CBR1000RR in one place.
2023 Honda CBR1000RR2023 Honda CBR1000RR
  • Price: $ 16,599 USD / $ N/A CAD
      • Rider-Assist Modes
      • Slipper Clutch
      • Electronic Steering Damper
      • Honda’s new Selectable Torque Control (HSTC) system
  • Colors: Grand Prix Red
Main Specs​
  • Engine: 998cc Four-cylinder
  • Power: 183 HP
  • Torque: 84 lb-ft
  • Wet Weight: 432 lbs (196 kg)
  • Seat Height: 833 mm (32.8 in.) at lowest point
Competitors​
  • Yamaha R1
  • Kawasaki Ninja ZX-10R
  • Suzuki GSXR-1000R
  • Ducati Panigale V4
  • BMW S1000RR
  • Aprilia RSV4
  • Triumph Speed Triple 1200 RR
2023 Honda CBR1000RR Specifications​
Engine998cc liquid-cooled inline four-cylinder four-stroke
Power183 HP
Bore x Stroke76mm x 55.1mm
Compression Ratio13:1
InductionProgrammed Dual Stage Fuel Injection (PGM-DSFI); 48mm throttle bodies; Denso 12-hole injectors
Starter
Valve TrainDOHC; four valves per cylinder
Clutch
TransmissionSix-speed
Final Drive#530 Chain; 16T/43T
Suspension Front43mm inverted Big Piston Fork with spring preload, rebound- and compression-damping adjustability; 4.7-inch travel
Suspension RearUnit Pro-Link® HMAS
single shock with spring preload, rebound- and compression-damping adjustability; 5.4-inch travel
Brakes FrontDual radial-mounted full-floating 320mm discs with four-piston calipers
Brakes RearSingle 220mm disc
Tires Front120/70ZR-17 radial
Tires Rear190/50Z-17 radial
Fuel Tank Capacity4.3 gallons
ColorGrand Prix Red
IgnitionDigital transistorized with electronic advance
Headlight
Tail Light
Overall Length
Ground Clearance
Trail3.8 inches
Wheelbase55.3 inches
Rake (Caster Angle)23.0°
Seat Height32.8 inches
Curb Weight432 pounds (Includes all standard equipment, required fluids and full tank of fuel—ready to ride)
2023 Honda CBR1000RR Features​
PERFORMANCE​
HI-PERFORMANCE FOUR-CYLINDER ENGINE
Featuring high-compression pistons, the CBR1000RR revs like only a flat-plane inline-four can. It also makes ten horsepower more than our previous generation CBR1000RR.
DUAL-STAGE FUEL INJECTION
The CBR1000RR features two sets of injectors per cylinder for both low- and high-rpm performance, instantaneous high-rpm response and great low-rpm metering and clean running. Refined EFI settings make the engine even more manageable, with smoother throttle response specifically at smaller throttle openings.
THROTTLE BY WIRE
The CBR1000RR’s throttle-by-wire system works in concert with our Honda Selectable Torque Control. With the two, you get your choice of three engine power-delivery modes, plus two which you can custom program yourself.
Honda ELECTRONIC STEERING DAMPER
Most steering dampers only sense handlebar-deflection speed. The Honda Electronic Steering Damper (HESD) is way more sophisticated. It also detects vehicle speed, and adjusts damping proportionally. That helps maintain low-speed maneuverability while providing excellent, predictable high-speed handling.
Honda SELECTABLE TORQUE CONTROL
With Honda Selectable Torque Control (HSTC), we’ve got your back, but you’re in control. Here’s how it works: The system automatically adjusts engine power to optimize torque at the rear wheel, reducing rear-wheel slip. You get your choice of five power curves, ten torque-control levels, three engine-braking levels, and now three selectable levels of wheelie control so it’s easier than ever to dial your bike in at the track.
HANDLING​
LIGHTWEIGHT SUB-FRAME
Almost a full pound lighter than our previous generation, the CBR1000RR sub-frame further refines our mass centralization efforts. Light is always right, and this is the lightest CBR1000RR we’ve ever produced.
GYRO ASSISTED ABS
The CBR1000RR ABS comes with anti-lock brakes. But these brakes go one better, including rear-wheel lift analysis (think hard stopping here), along with a program that takes lean angle into account.
SLIMMER ERGONOMICS
The CBR1000RR is much slimmer than previous models in the tank/seat junction area, and also in the upper cowl (more than 24mm trimmer than the previous generation). This improves aerodynamics, and the narrow tank makes it easier for the rider to tuck in out of the wind.
ENGINEERING​
TFT DISPLAY
TFT means an instrument display that’s lighter and easier to read than previous LCD designs.
ASSISTED SLIPPER CLUTCH
Superbikes can deliver a great deal of back-torque through the driveline, upsetting handling—not the CBR1000RR models. Its Honda-designed assisted slipper clutch is the same type used on our MotoGP bikes. The design does away with the need for heavy clutch springs, ensuring full power transmission with smooth shifting and a light clutch pull at the lever.
EFFICIENT RADIATOR DESIGN
Almost an inch narrower than on our previous-generation CBR1000RR, and featuring a high-density core. Plus the radiator tucks in tighter and cools just as efficiently.
DESIGN​
FULL LED LIGHTING PACKAGE
Headlights, taillights, turn signals—with the CBR1000RRs it’s all done with lightweight, efficient, cool LEDs.
2023 Honda CBR1000RR Photos​
2023 Honda CBR1000RR 2023 Honda CBR1000RR 2023 Honda CBR1000RR 2023 Honda CBR1000RR
2023 Honda CBR1000RR Videos​
2023 Honda CBR1000RR First Impressions and Walk-Around
Why spend an EXTRA $12,000? | CBR 1000RR vs CBR 1000RR-R SP
Honda Websites​
Other Links​
The post 2023 Honda CBR1000RR [Specs, Features, Photos] appeared first on webBikeWorld.
