D
Deleted member 1183
Yes indeed the movement is clear to see. Must check mine soon too. That is not good. I have been noticing an intermittent buzzing vibe thru the pegs while riding that I could not explain. Someone had a thread about that on here too. Perhaps this worn bearing could be the cause. I will have to jack my bike up as I don't have a centrestand. I am baffled that there is play on the sprocket side as there is always oil from the chain in that area so water should not be a problem ?
Addendum.
I just managed to do a preliminary check on mine by using one of the centrestand mountings as a jacking point. Admittedly I was in a cramped space in my shed but initially I cannot find any play whatsoever and all feels solid. When I have the bike out later next week I will check it again properly, but for now I am happy enough. I also have a habit of occasionally spraying some lubricant in around the seals of the shock pivot levers and the swingarm pivot seals. They are not easy to get at, but some light spray lube directed with a long tube can get close enough to drench the seals.
Addendum.
