tweak89
Umm....how?? I've owned a number of bikes over the last 20 years or so and have yet to see what I assume is the adjusting mechanism for our rear shock. I'm used to graduated rings that click into preset heights. It's adjustment is not even addressed in the manual, at least not the US version. And, unless I'm going crazy, most of the reviews mention the rear shock being adjustable for spring preload.
Is it as simple (assuming you can find the right size spanner wrench) as it looks, two rings that lock on each other?? Loosen them and tighten/loosen the ring closest to the shock spring to the desired height??
Seems pretty archaic.
