Lou Wambsganss
- Joined
- Oct 23, 2013
- Messages
- 279
- Reaction score
- 3
- Points
- 0
- Location
- United States, Dallas, TX
I have seen a few people mention this issue, but could not find a dedicated thread, so I figured I would start one. Hopefully, it won't be as bad as asking what oil I should use! Hopefully, if others read and comment on this post, new riders won't be caught off guard.
When I first test rode the bike, I was pretty conservative in the corners just as a general precaution. Once I took the bike home, during my first few days of riding it, I would gradually lean the bike further over in the turns as I got more comfortable with its handling. The first few times leaning into the ever-receding "Chicken Strips", I could feel a little bit of fish-tailing from the rear. The NC is my first brand-new bike, but I have put new tires on other bikes before and have never noticed any fishing to this extent. I have put a set of Metzeler ME880s on a Yamaha Virago and don't recall any issues with them when new...
The problem is with the thick waxy/greasy film on the tires. I have seen a lot of traffic on other forums and tire websites that says Mold Release Film is a thing of the past. No tire manufacturer uses it anymore. Brand new tires should be good to go right off the shelf. Maybe that is true for some, or even most, new tires. I can say form personal experience, however, that the Metzeler Roadtec Z8 Interacts on my 2012 Honda NC700X had a thick noticeable film when new. Maybe it's Mold Release Film. Maybe it's a protective coating for shipping/storage. I don't know if it's from Metzeler, Honda, or the Dealer. I just know that it's real, and very stubborn.
I could not remove the film with a green 3M Scotch-Brite pad and Simple Green or Windex Multi-Surface. The film would just smear. I couldn't make myself spray brand new tires with Brake or Carb Cleaner. Maybe something intended for tires like Westley's Bleche-White would remove it? I don't have any to test. I'd be careful, though. That stuff is STRONG, and would probably do bad things to an O-Ring chain, maybe even the painted wheels.
I tried removing the film with 180 grit paper on an orbital sander, and the film just clogged the paper. Maybe a larger grit (like 60-80) wouldn't clog as easily.
Anyway, the only way I've found to remove the film is by riding and wearing it off on the road. As you lean into the film, be careful. I was not expecting a loss of traction like that. Luckily, I was easy on the throttle, so the rear didn't go completely out from under me, just fished back and forth a few times. I was nowhere near dragging pegs or anything like that, and the road surface was clean concrete, ambient temps in the 50s-60s, tires were not cold. After a few turns leaning at the same angle, the fishing went away. It only happens the first few times you lean into the filmed area until the film is abraded off by the road.
Here is a picture of the film, as it is being worn off by normal riding. This is my daily driver on a short commute to work. I'm not carving any corners.
