oldmanaz
The T-Rexstands rear spools brackets showed up yesterday and got around to installing them.
The Left side bracket is the one that has many people asking "will it fit?". Well, the thickness of the bracket on the inside of the swing arm is 2mm (measured with my calipers). This side of the bracket does not have the isolating hard rubber. Clearance between the bracket and sprocket hub is VERY close but does not rub. When I dig out the feeler gauges later I will update with actual clearance.
Overall very happy with the fit and looks. One tip for installation: use a soft rubber or plastic faced hammer to slide the brackets over the swing arm as they are a very close fit. Also, the spool mounting bolt has the job of pinching the bottom bracket together. Instead of just running in the bolt to pinch it, use a pair of water pump pliers to pinch the bottom ends together and then run in the 8mm bolt. The threads in aluminum are soft and you may bugger them up if the ends aren't parallel.
The kit comes with 2 washers on each side to space the spool out. The two washers had to be removed for use with my Trackside rear stand. The arms wouldn't adjust to that width.
Pics and measurements to follow once the weekend rain stops.
